Home » Audio » Thermionic Emissions » Fixed Bias v. Cathode Bias
Re: Fixed Bias v. Cathode Bias [message #9063 is a reply to message #9062] Sat, 16 July 2005 19:46 Go to previous messageGo to previous message
Hi M, (sorry I forget your real name)
The main claim to fame of fixed bias, is efficiency, you get more power out of a set of tubes if you are not heating up a cathode resistor. But with FB you are applying a voltage, aka (signal) to the grid. If this is not deep black it will be heard.
With CB you will have a certain amount of degenerative feedback , which is not a bad thing and my guess is that is what you ( and me ) are hearing
With CB often you are running you tubes deep into "class A". You can test this. Measure current across the cathode resistor . then when you switch to FB set the current to the same or more.
Try this and tell me what you think…John
Previous Topic: I'm willing to reveal this about the Kit One:
Next Topic: Promise not to tell?
Current Time: Sat Nov 28 19:54:45 CST 2026
