Home » Audio » Speaker » WinISD 0.44
WinISD 0.44 [message #90465] Tue, 18 June 2019 13:18 Go to previous message
I like to play on winisd, goofing around with different woofers and alignments.
I noticed when you select either closed or ported enclosure, it gives an already established box and/or port size, with an established tuning frequency.
Ive read these are what is considered the best or most "commonly useful" alignments.
For the jbl 2226h, it shows this alignment-
/forum/index.php?t=getfile&id=2374&private=0
I don't see a peak at he tuning frequency, like you might see with an under-damped alignment,
but Ive definitely seen more over-damped alignments, especially when sealed...
What could you expect to hear subjectively, from this suggested alignment of
theirs, having a 52Hz tune at 73.5 Liters??
I would guess the woofer might unload frequently, especially with certain movies, below the port tune?
What might be the pros and cons??
Previous Topic: Cheapo earbuds
Next Topic: Rattling sound
Current Time: Fri Nov 06 10:35:14 CST 2026
