Home » Audio » Thermionic Emissions » Fostex 206 in custom cabinets, weak bass, please help!
Re: Fostex 206 in custom cabinets, weak bass, please help! [message #9011 is a reply to message #9007] Wed, 01 June 2005 16:35 Go to previous messageGo to previous message
paba is currently offline  paba
Hi Pete,
couple of things.
Those drivers need about 200 to 300 hours to break-in. I would wait for the break-in before trying to "fix" something.
second point, is that driver is really design for back-load horn. Even Fostex says so, and even though they provide the 45 liter box example it really will never do much in such a box. atleast not without a correction circuit. Then this circuit will eat up the efficiency you need with 9 Watts, cause it could brink you down to a few dB.
My best advice is after the breakin if you still don't like it move to the other cabinet Fostex recommends.
good luck
paba
Previous Topic: Power Supply suggestions
Next Topic: SEX
Current Time: Tue Nov 03 06:42:59 CST 2026
