I already have both JBL 2226h and B&C DE250 and have tried to make an active speaker both I have trouble with hisss sound from my Minidsp so I want to try something else.
I have the JBL 2226 15" woofer. I'm choosing between the JBL and B&C driver. Just wondering if an Eminence Alpha 15A will work? Thank you for any help.
Wayne Parham Messages: 19097 Registered: January 2001
You've got mail!
The JBL 2226H sounds very good in the four Pi cabinet. You cannot use the Eminence Alpha 15A because it has very different electro-mechanical specs. The design requires either the JBL 2226H or the Eminence Omega 15A. The JBL driver is the better of the two because it has a flux-stabilization ring to reduce distortion.
I suspect I may be doing something wrong,but recieved your "Youve got mail" notice, but without attachment.
Is there some trick to viewing the 4Pi plans I should know?
