Home » Audio » Source » Converting vinyl to mp3
Re: Converting vinyl to mp3 [message #89638 is a reply to message #89611] Tue, 29 January 2019 10:45 Go to previous messageGo to previous message
Hi, If the analog source is high quality then the MP3 will be much worse. OK for listening as background or in the car. Using a typical phono preamp (some good ones are in the $100-200 range) you can digitalize the output in a PC or via a dedicated device and (I use a SIIG external sound "card")save the file in a much higher resolution. I like 24/96 (native format no software in the SIIG) as the files are not too huge and nearly any program can handle them. Hard to tell them from the original material. If you use Audacity you can edit them and clean up much in the way of defiencies. Steep sub audio cut to remove sub sonics and if you have the patience you can individually remove clicks and pops. The auto setting is OK, but not perfect. Lots of other things can be done too. After the edit, you can decide what format to export the files. I use .wav as all my devices can use it and it sounds great. There are plenty of choices to suit your needs.
Previous Topic: Will streaming kill the vinyl resurgence
Next Topic: Capturing Movie Soundtracks
Current Time: Fri Nov 27 07:07:13 CST 2026
