Home » Audio » Measurement » Audio Measurement Mic
Audio Measurement Mic [message #89486] Fri, 04 January 2019 10:05 Go to next message
Lost the Remote is currently offline  Lost the Remote
I'm looking to purchase an audio measurement mic and I've noticed that prices are all over the place. Is this one of those things where the higher price tag equals greater accuracy and ease of use, or is it okay to buy a budget model? I've used a Dayton Audio Measurement Microphone (UMM-6) before, but I had nothing to compare it to and the necessary software was already on the computer.
Re: Audio Measurement Mic [message #89498 is a reply to message #89486] Sun, 06 January 2019 21:21 Go to previous messageGo to next message
musicluvr is currently offline  musicluvr
I wouldn't spend big bucks on anything that's high-end with all the bells and whistles unless you need it professionally. Buying something mid-range would probably be sufficient for a hobbyist interested in audio system tuning.
Re: Audio Measurement Mic [message #89515 is a reply to message #89486] Mon, 07 January 2019 14:30 Go to previous message
Hi I use the UMM6 with both a PC and with a Behringer DEQ2496 (it actually is given in some of their literature as suitable). The issue is more complex than just what mic to use. Placement, loudness, room reflections and nodes have a great effect on the accuracy of your measurements.
Previous Topic: Audio measurement tools
Next Topic: Room EQ Wizard.
Current Time: Sat Oct 31 13:15:05 CDT 2026
