Home » Sponsored » Pi Speakers » Amp for 4pi speakers (Integrated stereo amp without dsp or AVR with audyssey)
Re: Amp for 4pi speakers [message #89288 is a reply to message #89287] Tue, 27 November 2018 16:47 Go to previous messageGo to previous message
In my experience, 200Hz is about the limit of the flanking sub (helper woofer) approach. But I've blended the woofer with the mid(woofer) to ~250Hz in some loudspeakers and it has worked well.
Some specialized cases, like the constant directivity cornerhorns, allow for a wide overlap band. Many 2.5-ways are designed this way too. The midwoofer and helper-woofer are in fairly close proximity, so they can overlap to fairly high frequency.
But when I've run subwoofers as "helper woofers" - in the configuration I call "flanking subs" - I generally don't run them that high. They are localizable if the rolloff if made too high. I generally use low-pass between 90-120Hz second-order, which provides quite a bit of output in the 100Hz to 200Hz region because rolloff is so gradual.
You could try 150Hz second-order, which would definitely provide output up to 200Hz and beyond. But it might start to sound unnatural when run that high.
As for the modal smoothing below 100Hz, please do a search here for multisub setups. There are a few approaches, but most agree that if you have four subs (or more) it almost doesn't matter where you put them. Just don't cluster them together - Place them around the room.
Previous Topic: 4pi build and questions
Next Topic: 7Pi Build 2014
Current Time: Tue Oct 20 22:49:47 CDT 2026
