Home » Audio » Home Theater » Large Screen TV or Projector (Which is better for Home Theater?)
Large Screen TV or Projector [message #88631] Thu, 09 August 2018 02:54 Go to next message
Malfoy is currently offline  Malfoy
Which is better for a home theater setup, a large screen TV or a projector? In the past, projectors were expensive so the TV was the choice of many homes. Today, large screen TV's can be more expensive than projectors, depending on the brand and quality.
Re: Large Screen TV or Projector [message #88704 is a reply to message #88631] Mon, 20 August 2018 22:08 Go to previous messageGo to next message
Junior is currently offline  Junior
I think projectors are good to have with the advancement of technology. I don't know though if the projectors can have the resolution that TV's have today.
Re: Large Screen TV or Projector [message #88948 is a reply to message #88704] Sun, 07 October 2018 10:14 Go to previous messageGo to next message
Junior wrote on Mon, 20 August 2018 22:08
My thoughts as well because I am yet to come across a projector that would give a resolution similar to that of a TV. I have always preferred TVs, for this simple reason.
Re: Large Screen TV or Projector [message #88951 is a reply to message #88948] Sun, 07 October 2018 12:06 Go to previous messageGo to next message
There is one big advantage when using a projector - You can place the center channel speaker behind the screen. That allows a good quality loudspeaker to be used.
Most center channel speakers that are designed to mount below a television are terrible. You really can't make a good loudspeaker that's short and wide. The typical design uses horizontally arrayed drivers, which then create lobes and nulls in the listening area. I'd rather have a phantom center than that.
Re: Large Screen TV or Projector [message #88952 is a reply to message #88951] Mon, 08 October 2018 15:41 Go to previous messageGo to next message
Wayne Parham wrote on Sun, 07 October 2018 12:06
I guess then that a projector only has the advantage of enabling good sound quality, but not necessarily good picture quality/resolution. What's the best resolution that you can get via a projector?
Re: Large Screen TV or Projector [message #88953 is a reply to message #88952] Mon, 08 October 2018 16:17 Go to previous messageGo to next message
Let me expound on the issue with the center channel. My expertise is loudspeakers.
You can get great sound without a center channel speaker. When the left and right mains generate relatively constant directivity and they are are setup where their forward axes cross in front of the listening position, they make a fantastic phantom center. This is the holy grail of stereo, and it makes a very good impression of realism even without a center channel speaker.
That said, it's better to also have a center channel speaker if it doesn't require a compromised loudspeaker configuration. That means having a center channel speaker that matches the left/right mains.
Re: Large Screen TV or Projector [message #89156 is a reply to message #88631] Sun, 11 November 2018 13:21 Go to previous messageGo to next message
Duks is currently offline  Duks
If you have the ideal conditions, such as a dark enough room and a good surface to project on to, then getting a projector makes sense. I would rather have a large screen though.
Re: Large Screen TV or Projector [message #89180 is a reply to message #88631] Mon, 12 November 2018 18:18 Go to previous message
Reggie is currently offline  Reggie
Hello there again Wayne. So what you are saying is that when the speakers on the TV are on the sides instead of under the screen, then the phantom center is achieved for the TV. Is my understanding correct?
Previous Topic: Location Setting For Sound Quality
Next Topic: Lifespan of Plasma TV?
Current Time: Fri Nov 13 06:24:07 CST 2026
