Home » Sponsored » Pi Speakers » Questions on 2Pi tower build
Questions on 2Pi tower build [message #88833] Sun, 16 September 2018 19:37 Go to previous message
OneBean is currently offline  OneBean
So the slowest moving project ever might actually get off the ground. I have some questions regarding the construction of the 2Pi towers.
The plans show the speakers foot print as 16" wide, and 13" deep. Would it effect the sound quality if I rotate the 13" to the front, and mount the drivers into the 13" side?
Does it effect the sound quality if I flush mount the drivers? I only consider doing this for visual appeal.
Should I use a quality sanded plywood or MDF?
Thanks for the advise.
Previous Topic: 8PI Plans Request
Next Topic: Used JBL2226H, good/bad idea?
Current Time: Thu Nov 12 18:25:03 CST 2026
