Home » Audio » Room Acoustics » Small-room acoustics
Re: Small-room acoustics [message #88455 is a reply to message #88454] Tue, 17 July 2018 15:17 Go to previous message
The problem in small rooms isn't sound pressure level, because that's easy enough to fix simply by turning the volume down.
The problem is room modes; Regions that have no bass at some frequencies adjacent to regions with too much bass at some frequencies.
A number of subwoofers placed around the room will provide more uniform sound than a single subwoofer. Each sub is driven at very low power levels - an amount appropriate for balanced sound.
Three or four subs run this way will create much smoother bass throughout the room than a single sub will, even if the one sub generates as much acoustic power. The single sub will sound boomy in some locations and thin in others.
Previous Topic: Shapes of acoustic panels
Next Topic: Soundproof on a budget
Current Time: Tue Oct 20 12:50:26 CDT 2026
