Home » Sponsored » Pi Speakers » Four Pi crossover adaptable to 16R JBL 2226? (Can the PCB Xover hold components for 16R woofer?)
Four Pi crossover adaptable to 16R JBL 2226? [message #88260] Thu, 28 June 2018 06:55 Go to next message
tubino is currently offline  tubino
I already have a nice pair of JBL 2226 I'd like to use in a Four Pi build, but they are the J or 16 ohm version. I assume the PCB crossovers are designed for 8 ohm woofers. Is that assumption correct, and if so, can the halving/doubling of caps and inductors fit on that board?
And if so, can that be specified when boards are ordered?
Re: Four Pi crossover adaptable to 16R JBL 2226? [message #88269 is a reply to message #88260] Fri, 29 June 2018 09:57 Go to previous message
The crossover is designed for the 2226H. You might be able to scale the woofer circuit parts to use the 2226J, but I haven't tested it. Might need some fine-tuning. And don't forget the voltage sensitivity shift - You'll need to change the tweeter attenuation to compensate.
Previous Topic: 7Pi thoughts and questions
Next Topic: Eminence H290B vs. H290C vs H290S
Current Time: Mon Nov 23 02:18:19 CST 2026
