Home » Audio » Speaker » Replacing The Subwoofer
Replacing The Subwoofer [message #88188] Sat, 16 June 2018 09:09 Go to next message
Jazzy is currently offline  Jazzy
If you the choice to replace a broken subwoofer, will you replace the subwoofer only or is it better to buy a new speaker altogether? My subwoofer is not sounding any longer but the small speakers are still working fine.
Re: Replacing The Subwoofer [message #88207 is a reply to message #88188] Mon, 18 June 2018 23:28 Go to previous messageGo to next message
Malfoy is currently offline  Malfoy
I suggest you buy a new set of speakers. You can buy a subwoofer but that might not be compatible with the speakers you have. Spending that extra buck will give you a better sounding speaker compare to fixing your old speaker.
Re: Replacing The Subwoofer [message #88209 is a reply to message #88207] Tue, 19 June 2018 10:11 Go to previous messageGo to next message
Thanks for the advice and I will save up money to buy a new set of speakers. There are many Chinese-made speakers nowadays, do you think it is good to buy one of those? Or should I stick to the known brands like Bose or Kenwood?
Re: Replacing The Subwoofer [message #88258 is a reply to message #88209] Thu, 28 June 2018 02:18 Go to previous messageGo to next message
Almost everything today is made in China, even the best brands that we have right now. I say go with your budget and check on the quality of the speaker before buying it. You can also ask advice from the seller as that person can give you a better idea.
Re: Replacing The Subwoofer [message #99791 is a reply to message #88258] Sun, 13 September 2026 13:09 Go to previous messageGo to next message
George is currently offline  George
Malfoy wrote on Thu, 28 June 2018 02:18
It is all about the quality. I don't bother asking sellers for tips on the bedr gears to get when I visit their shops, I do my due diligence online by asking those who use similar products before I go shopping. That way, I am sure of what I am trying to get.
Re: Replacing The Subwoofer [message #99899 is a reply to message #99791] Sun, 01 November 2026 10:39 Go to previous message
Kurt is currently offline  Kurt
George wrote on Sun, 13 September 2026 13:09
Well, George, I totally get why you skip the sellers, but I am still of the view that it is not all good.
I've been in situations where I got valuable hints about certain subwoofers from the shop guys who's gotten real reviews from buyers on a daily basis. I am not disregarding the fact that quality matters a lot, but there are situations where I've been told an issue that I never knew might exist about a product from the sellers when I interacted with them.
I would want to know if you've ever tried chatting with a seller after doing your research? I mean, there is no harm in making enquiries or have you had an ugly experience from asking?
Previous Topic: Wireless Speaker
Current Time: Fri Nov 13 07:53:30 CST 2026
