Home » Audio » Source » Buying a record player
Re: Buying a record player [message #88193 is a reply to message #87576] Sun, 17 June 2018 09:08 Go to previous messageGo to previous message
I prefer direct drive tables. But not the knock off's to the Technics 1200. I used a Rega prior and it was prone to feedback and speed variation that made piano's seem to go out of tune and vocal fluctuation's. Quartz controlled direct drive has rock steady speed and in the 1200 case, heavily damped in the plinth to help prevent feedback getting fed back into the tonearm. The market for used or vintage tables is hot these days. But, good deals can still be had. For the novice, I think the Technics SL-Q line of table's offer quartz drive and idiot proof means of cartridge alignment called p-mount. Simply, the cartridge plugs into the tonearm and secured by a mounting screw. No other alignment required other than adjustment of the VTF, (vertical tracking force) and anti skating adjustment, (force exerted on the stylus as it travels across the record). These table's can usually be bought for a relatively reasonable price. It's true that buying used can be a crap shoot. I still think you've got dealer odd's going for you.
Previous Topic: What would you do with a load of old 78's?
Next Topic: How do you buy most of your music?
Current Time: Mon Nov 16 09:44:57 CST 2026
