Home » Sponsored » Pi Speakers » Build Thread: 2Pi Towers, 6Pi Corner horns (and possibly a sub and center) (Building some Pi Speakers)
Re: Build Thread: 2Pi Towers, 6Pi Corner horns (and possibly a sub and center) [message #88172 is a reply to message #88057] Wed, 13 June 2018 07:17 Go to previous messageGo to previous message
Awesome build!
Just a couple of observations-
You had mentioned the six pi Corner horn being smaller than the seven pi.
I believe it is the other way around, with the six pi tuned to about 1/2 an octave lower.
As far as the two pi's lacking in punch.
It has been my experience that woofers (especially high sensitivity) will loosen up and break-in, improving in just that range (mid bass).
My four pi's slowly broke in, increasing in the mid bass.
Experience also tells me that amplifier topology also has a part to play in this.
I used an Adcom 555, with moderate punch.
Then a set 300 b with a bit less punch.
Now two medium size mono blocks using Kt 88 tubes, they pretty much punch you in the face.
Ymmv.
Previous Topic: 3pi crossover
Next Topic: 12pi hornsub questions
Current Time: Tue Oct 20 11:40:51 CDT 2026
