Home » Audio » Thermionic Emissions » Guitar Amp
Guitar Amp [message #88126] Wed, 06 June 2018 14:16 Go to next message
utopia is currently offline  utopia
I've been shopping around for a guitar amp recently. I play in a band and my current amp isn't powerful enough to be heard over our drummer. How many watts do you typically need for a tube amp to be heard over other instruments?
Re: Guitar Amp [message #88133 is a reply to message #88126] Thu, 07 June 2018 13:34 Go to previous messageGo to next message
Kinsley is currently offline  Kinsley
What size are the venues you typically play in? If they're on the smaller side, I would think you'd be good with 40-60 watts. You would probably have to go higher for larger venues though.
Re: Guitar Amp [message #88439 is a reply to message #88126] Sat, 14 July 2018 17:57 Go to previous messageGo to next message
Floyd is currently offline  Floyd
And if you are playing in pubs or similarly small places you may even have to go less than 30 watts, unless you really want to blast the place with sound!
I notice Fender do some quite good amps, and you can pick them up second hand.
Re: Guitar Amp [message #92350 is a reply to message #88126] Wed, 23 September 2020 17:30 Go to previous messageGo to next message
If you like your current amp, can you overcome the issue by mic'ing into the PA and monitors? Other options are more efficient speakers (or more speakers), again, if you like the amp you have. Otherwise, it's a wide open world of choices.
Good luck either way.
Re: Guitar Amp [message #92477 is a reply to message #88439] Thu, 22 October 2020 20:12 Go to previous message
The Noise is currently offline  The Noise
Floyd wrote on Sat, 14 July 2018 17:57
While that might be amusing to see, most clubs are going to see the equipment before the band goes on. If you can afford amps that will shake the foundation of a bar, you'll be playing in larger venues.
Previous Topic: Microphonic KT120s
Next Topic: Trigger finger is itchy
Current Time: Fri Nov 13 07:02:22 CST 2026
