Home » Audio » Thermionic Emissions » Power supply rectifiers
Power supply rectifiers [message #8810] Fri, 04 February 2005 17:57 Go to next message
While building the Stoetkit, I noticed that it uses 1N400x rectifiers. All of the signal capacitors are nice, and the transformers are great. But the power supply uses electrolytics and plain ol' 1N400x diodes. So I think maybe I could probably improve some there, just with component substitutions.
We've had discussions on this forum about fast recovery diodes, FREDs and HEXFREDs and also about Schottky diodes. I'm thinking one of my first upgrades will be to improve the rectifiers, but I'm wondering which to go with. I'll probably grab some datasheets and give this some thought, and I'd also like to hear your experiences.
Re: Power supply rectifiers [message #8811 is a reply to message #8810] Sat, 05 February 2005 06:23 Go to previous messageGo to next message
I replaced all the 5014's in my AES pre-amp with schottkey's. It actually made quite a difference in the sound, more full and sweet with better, deeper bass and lot's more prescence.
SiC Schottky by Cree [message #8813 is a reply to message #8810] Sat, 05 February 2005 20:26 Go to previous messageGo to next message
i think tube Builder i Maryland stocks these. They were an improvement over Fairchild Stealth ( fast/soft recovery ) in one of my amps. I would not have paid $12.50 each for the 1k2V/5A versions, but since Cree saw fit to sample me 8 of them...I share my positive experience when ever possible.
regards,
Douglas
Re: Power supply rectifiers [message #8814 is a reply to message #8810] Sun, 06 February 2005 06:23 Go to previous messageGo to next message
I had trouble getting Tube Builder to reply when I bought my second set so went to Digikey for Infineon brand:
Infineon 600V @ Digikey
The Infineons seemed a bit less fragile also.
No question they are MUCH quieter and allow more detail of the music thru.
Re: Try a Snubber Filter, too... [message #8815 is a reply to message #8810] Sun, 06 February 2005 10:50 Go to previous messageGo to next message
TubeCraft is currently offline  TubeCraft
The Bottleheads swear by them. I think all the parts can be had at the Rat Shack. It's just like a Pi filter but with an identical resistor in both lines. Use RS ceramic .01 1.5kv for the caps and cheap 10R 10W cement resistors (the more inductive the better). The resistors really help the inrush problem too. I built my regulated bench supply this way.
Transformer>snubber>diodes>PS filter
--|--VVVV--|--->|---
--|--VVVV--|--->|--
Just a thought.
Regards,
TC
Re: So much for my attempt at ASCII.... [message #8816 is a reply to message #8815] Sun, 06 February 2005 10:52 Go to previous messageGo to next message
...schematic drawing :>)
I gotcha [message #8817 is a reply to message #8816] Sun, 06 February 2005 11:50 Go to previous messageGo to next message
I understood what you meant. An RF filter on the AC input.
I gotcha [message #8818 is a reply to message #8817] Sun, 06 February 2005 16:38 Go to previous messageGo to next message
Hey-hey!!!,
I got forced into using a common TX for both the B+ and a DC filament supply. It is Schottky rectified and L-C, but there is still a little bit of buzz which matches the switching of the diodes. It is just at edge of perception, but knowing why it is there is bugging me.
Guess I'll put a dedicated TX under there and be done with it. this'll give me a few more options for other experiments. I am going to put .01 uF caps across each of the Schottky diodes and see if that helps first...
regards,
Douglas
Re: Power supply rectifiers [message #8832 is a reply to message #8810] Sat, 19 February 2005 20:45 Go to previous messageGo to next message
Poindexter is currently offline  Poindexter
Hey, Wayne,
Sorry to enter the fray so late.
My budget fave is Diodes, Inc. ultrafast switching rectifiers, their number UF1007, which have otherwise the exact same specs as 1N4007.  Digi-Key sells these for 29¢, if you buy a hundred; a lifetime supply for a hobbyist.  They are not 'soft' recovery, but their PN burst is very high-freek and short duration; thus very easily shuntable.  I use a .01µF 716P on each side of the diode set (transformer and filter), and have gotten very good results; clear, fast, quiet.
How many you need for your Stoetkit? I'll send them along.
Poinz
Re: Power supply rectifiers [message #8834 is a reply to message #8832] Sun, 20 February 2005 04:06 Go to previous messageGo to previous message
Cool, thanks! The Stoetkit uses four.
Previous Topic: It's finally being printed!
Next Topic: ASL Explorer 805 DT schematic is available.
Current Time: Tue Oct 20 17:28:00 CDT 2026
