DSP for subwoofer(s) [message #88044] |
Sat, 19 May 2018 11:55 |
Rusty
Messages: 1161 Registered: May 2018 Location: Kansas City Missouri
Illuminati (3rd Degree) |
Hello Wayne, hope your doing well.
I was looking at doing subwoofers for my old Theater 4 Pi's.
Actually I've been satisfied with the bass output of the eminence delta's in it. But I've had in box, (for many years) a real nice JBL 1500 subwoofer that really I should hear that this thing lives up to it's legacy. Space though is an issue. Those thermionic Pi's take up a lot of space. And I think the Pi subwoofer's are just too large a box unfortunately. Wonder if the Parts Express RSS10 subwoofer's could give adequate output then having the JBL behind the listening position.
Most electronic crossovers though only have high crossover slopes.
To implement these subs I've contemplated using the mini DSP device. I have a nice Hafler 9505 I could power the two 10's and a plate amp for the JBL.
My long winded question, (drum roll) is, The DSP seemingly has all the functions for crossover types and slopes, and fairly cheap, but I'm really not interested in doing all the measurement aspect using a usb mic. Essentially, using your recommendation of running the main speakers full range, I just want to plug in the crossover point, slope and level, listen and hopefully be done.
My thinking is your multi sub approach is fundamentally more important than all this DSP configuring and doing tedious minute measuring and tweaking. Your crossover network budget wise is tempting, works best with modifications. I just want to use the power sources I have and implement it the easiest non tweaking, modifying way. I'm older and retired and my impetus now involves a bit of loitering and lollygagging. Not fussing with complicated audio disciplines as in the past.
Re: DSP for subwoofer(s) [message #88045 is a reply to message #88044] |
Sat, 19 May 2018 12:41 |
Messages: 18761 Registered: January 2001
You're right - the main thing is number and placement of subs.
I understand that you want to use a DSP crossover because it gives you the ability to choose any crossover point and slope you want, so will be easy to set the requisite ~90Hz second-order low-pass slope for the flanking subs. That's a great idea.
As an aside, using DSP for subwoofer EQ is overkill. It's not bad at all, but will give less and less improvement in overall sound quality as the number of subs increases. And if using a small number of subs, EQ becomes more important, but then again, you can only EQ for one position. All other places in the room will suffer. I would argue that if you're going to use just one sub, it should be placed nearfield and the volume adjusted accordingly. You'd still have only one good spot in the room - right where the subwoofer is located - but EQ would be less necessary because you would be very close to the subwoofer.
Anyway, I digress. Back to the multisub approach:
Ideally what you want is a pair of flanking subs and a pair of distributed multisubs. The mains are run fullrange, or for really high-output requirements, the mains can be high-passed at the Helmholtz frequency to prevent overexcursion. That just removes the content that wouldn't be heard anyway. The flanking subs are low-passed around 90Hz to 100Hz, second-order. They are placed just beside, behind and below the mains. The distributed subs are placed at the opposite end of the room, and are low-passed around 50Hz to 60Hz, fourth-order.
After you've done that, you will have achieved at least 90% of the best you could accomplish. The main thing is the placement of the subs, the fact that they are distributed around the room. But if you want to try to get even closer to perfection, you can fine-tune the position and the EQ of the distributed multisubs. Focus on them one at a time. Start with the nearest sub, and after you've gotten the best response, go to the farthest sub. Be sure to measure at several locations when evaluating EQ. You're looking for overall smoothing, not just best response at one place.
