Home » Audio » Craftsmen » How to make Bass Traps
Re: How to make Bass Traps [message #87883 is a reply to message #87879] Fri, 27 April 2018 13:32 Go to previous message
In my experience corners are considered to be the best place for bass traps, or at least the best place to start in a standard residential room.
But they need to be very thick to absorb bass.
The cheapest and most typical diy bass trap is just a 2'x4' piece of compressed fiberglass (ex. Owens 703) set up vertically in a corner, with some batt insulation loosely shoved behind it.
You could also stack them, creating an 8 foot tall trap
It could be covered with a thin, acoustically transparent material like cheap spandex (stocking material).
The traps that I have built over the years, never use any type of frame or backing material.
The bass wave travels directly through the material, bounces off the back wall and then has to travel back through the trap and into the room again.
This is different than a resonant panel absorber
Previous Topic: DIY/Hacks That Failed
Next Topic: Safety Gear
Current Time: Mon Nov 02 02:52:46 CST 2026
