Wayne Parham Messages: 19108 Registered: January 2001
Midhorn plans are shown in the links below. They're conical horns, meaning they use straight-sided walls in the horn flare. That makes them relatively easy to build. I'd suggest making a mock-up with cardboard, and then use your cardboard pieces as a template to cut your wood.
Information about the midrange horn used in our constant-directivity cornerhorns can be found in the following threads:
