Home » Sponsored » Pi Speakers » pi 10" midrange horn plan request
pi 10" midrange horn plan request [message #87871] Tue, 24 April 2018 13:23 Go to next message
antixsounds is currently offline  antixsounds
Hello I'm very interested in building a portable full range horn loaded cabinet and think your midrange horn would be ideal. Would you mind sending me the plans for them please.
Would also be interested to know the volume required by rear chamber and would it change with a different driver?
Regards Oliver
Re: pi 10" midrange horn plan request [message #87872 is a reply to message #87871] Tue, 24 April 2018 15:02 Go to previous message
Midhorn plans are shown in the links below. They're conical horns, meaning they use straight-sided walls in the horn flare. That makes them relatively easy to build. I'd suggest making a mock-up with cardboard, and then use your cardboard pieces as a template to cut your wood.
Information about the midrange horn used in our constant-directivity cornerhorns can be found in the following threads:
Previous Topic: Mid-horn Plans request
Next Topic: Pi 3 Sub Plans Request
Current Time: Sat Nov 21 22:03:31 CST 2026
