Home » Audio » Silicon Valley » Crackling
Crackling [message #87307] Wed, 28 February 2018 22:39 Go to next message
Spidey is currently offline  Spidey
A couple of years ago, I ended up ditching an amp that I'd had for a few years because there was a really loud crackling noise that would start about five minutes after turning it on. It was a relatively cheap amp (and I'd been lusting over a different one for a few months), so I ended up putting it aside and getting a new one. Now I kind of want to use it again. Is this something that I could potentially fix without having to bring it in to get repaired?
Re: Crackling [message #87311 is a reply to message #87307] Thu, 01 March 2018 09:03 Go to previous messageGo to next message
Resolder all the solder joints on the board and look for electrolytic capacitors that have swollen. If you find any that have rounded tops, replace them. Also look for any other component that looks like it has gotten hot, and replace any that look discolored from heat. If after that it still crackles and pops, you'll need to troubleshoot with an oscilloscope. That may be beyond the level of effort you're willing to do.
Re: Crackling [message #87391 is a reply to message #87307] Wed, 07 March 2018 12:47 Go to previous messageGo to next message
Thanks for the advice! There are a few electrolytic capacitors that look swollen, so I'm going to replace them. I haven't checked closely for the other issues you mentioned, but I'll give them a closer inspection if this doesn't do the trick. Thanks again!
Re: Crackling [message #99100 is a reply to message #87391] Tue, 18 November 2025 23:42 Go to previous message
Becky is currently offline  Becky
Honestly, it might be something simple, but it really depends on what’s causing the crackling. A lot of amps start doing that when a part inside gets old, like a dirty pot, a loose connection, or something heating up after a few minutes. Sometimes just cleaning the knobs with contact cleaner can help, but other times it’s more of an internal issue.
Since it starts after the amp warms up, that usually means a part inside isn’t super happy anymore. You could pop it open and look for dust or loose wires if you’re comfortable, but if not, it might be safer to get someone to check it. I’d hate for you to try fixing it and make things worse.
If you really wanna use it again though, it’s definitely worth trying a basic cleaning first.
Previous Topic: Tubes versus Transistors
Next Topic: Do you think getting a customised solid-state amp is a waste of money?
Current Time: Mon Nov 02 02:04:56 CST 2026
