Home » Audio » Source » Variac
Variac [message #86984] Fri, 12 January 2018 09:50 Go to next message
Does this seem like a good little auto transformer?-
http://www.iseincstore.com/3pn1010bvariabletransformer120vacsinglephaseinput0-140vacoutput10acasedmodelwithcordplugreceptaclelightedswitchandfuse.aspx
I believe it is American made.
Re: Variac [message #86985 is a reply to message #86984] Fri, 12 January 2018 10:02 Go to previous messageGo to next message
That's a Staco unit, and it's a good product. We used those on the bench at electronics classes back in school. Staco is an American company and have been around for decades.
You might check to see if Digikey has them, 'cause they're usually really competitive on price.
Re: Variac [message #86986 is a reply to message #86984] Fri, 12 January 2018 10:05 Go to previous messageGo to next message
Your right Wayne-
https://www.digikey.com/product-detail/en/staco-energy-products-company/3PN1010B/452-1003-ND/526078?utm_adgroup=Test%20&%20Measurement
Thanks.
Re: Variac [message #86991 is a reply to message #86986] Fri, 12 January 2018 16:08 Go to previous messageGo to next message
Ouch, $400+. If you can get by with 5 amps instead of 10 then the one in the link below is just fine.
https://www.ebay.com/itm/TDGC-0-5KM-500VA-Variable-Output-AC-Convertor-/152215213803
I use it both on the bench and to control a crock pot. Works fine.
Re: Variac [message #86992 is a reply to message #86984] Fri, 12 January 2018 16:49 Go to previous messageGo to next message
Yes the Chinese one are much cheaper.
Re: Variac [message #87096 is a reply to message #86984] Sun, 21 January 2018 09:54 Go to previous messageGo to next message
I ended up getting this one used on Ebay for $131.-
index.php?t=getfile&id=2050&private=0
You can't tell from the crummy i-phone pic, but it appears gently used, and the knob turns nice and smooth.
Seems built like a tank.
I checked it with one of my cheap ass meters lol.
Plugged into an outlet (which reads 125.9V) at my workstation, it measures as follows-
Set at output 0-120V, it maxes out at 125.2V.
Set at output 0-140V, it maxes out at 151V.
  • Attachment: IMG_2663.JPG
    (Size: 115.49KB, Downloaded 1012 times)
Re: Variac [message #87097 is a reply to message #87096] Sun, 21 January 2018 10:18 Go to previous message
Oh, very good.
I'll bet your gear will like a nice even 110vrms signal from that.
Previous Topic: Marantz SLT 12 / SLT 12U Questions!
Next Topic: Converting cassette tapes to digital format
Current Time: Sat Nov 07 00:02:25 CST 2026
