Home » Audio » Radio » Which kit to convert analog to digital?
Which kit to convert analog to digital? [message #86739] Tue, 12 December 2017 22:50 Go to next message
Which kit do you all recommend I buy in order to convert an analog radio into a digital radio? Is it something a newbie should be able to do?
Re: Which kit to convert analog to digital? [message #86740 is a reply to message #86739] Tue, 12 December 2017 23:45 Go to previous messageGo to next message
Aria is currently offline  Aria
The semi-integrated kits (meaning they need a remote) are going to be easier to set up than the fully integrated ones which, from what I hear, are pretty difficult to set up. So how easy it would be for you depends on what kind of kit you want.
Re: Which kit to convert analog to digital? [message #86765 is a reply to message #86739] Wed, 13 December 2017 19:53 Go to previous messageGo to next message
Hi, There are lots of possibilities. Exactly what are you trying to convert from and what are you trying to convert to? What resolution and what format do you want the output to be in?
Re: Which kit to convert analog to digital? [message #86789 is a reply to message #86765] Fri, 15 December 2017 22:51 Go to previous message
Thanks to both of you for the assistance. It's a REALISTIC brand UHF or maybe UVHF (hard to see) AM/FM scanning receiver. The serial number is faded to the point that I can't see it. It about thirty years old, but it worked fine until everything switched to digital.
Previous Topic: Podcast recommendations for young kids
Next Topic: Holiday spirit
Current Time: Sun Nov 01 23:11:41 CST 2026
