Home » Audio » Thermionic Emissions » rogue 88 amp
Re: rogue 88 amp [message #8660 is a reply to message #8557] Sat, 08 January 2005 05:32 Go to previous message
Does the amp work properly? If so, I'd probably use the smallest value fuse that will work at full power without blowing. If you have a meter, you can insert it into the circuit where the fuse goes and measure the current. If not, try a relatively small value fast-blo fuse at first and work your way up to a value that doesn't blow.
Previous Topic: K-502 Report
Next Topic: tube sub info
Current Time: Fri Sep 18 11:07:25 CDT 2026
