| Why is drywall bad? [message #86385] |
Wed, 25 October 2017 11:43  |
lilbill
Messages: 134 Registered: August 2016
Master |
All I've heard is that drywall is cheap and economical and that's it's made of natural materials. However, I have come across literature that claims that it is not recommended at all. What are the reasons behind this?
| Re: Why is drywall bad? [message #86463 is a reply to message #86461] |
Thu, 02 November 2017 10:13   |
Messages: 19052 Registered: January 2001
That's true. Rooms with framed drywall construction are much better than rooms with brick, stucco, concrete or rock walls. The drywall panels vibrate enough that they absorb some of the bass frequencies, and so act a little bit like panel absorbers.
But to Bruce's point, even that isn't enough if the room doesn't have more absorbent stuff in it. I've heard drywall rooms that had flutter echo so bad they sounded like a bird chirping, especially when given a transient signal like a hand clap.
I do find that rooms with framed drywall construction and wall-to-wall carpeting with ample furnishings are usually pretty well behaved. They can be improved upon, sure, but I think most people in homes with framed drywall rooms have at least a good starting point.
Many don't need additional acoustic treatments to sound good, especially when the sound system uses technologies that mitigate room acoustics problems. A directional loudspeaker that is properly placed will help minimize early reflection problems, and should create a tonally-uniform reverberent field. And flanking subs and multisubs will mitigate room modes and reflection problems in the lower end of the frequency scale.
| Re: Why is drywall bad? [message #86573 is a reply to message #86385] |
Fri, 17 November 2017 06:20  |
Rockman
Messages: 8 Registered: November 2017
Esquire |
Acoustics aside, I have heard many reports of drywall being associated with stuff that is bad for health. For one, you have to make sure that it is free of asbestos. Secondly, I heard many reports of toxic mold being associated with drywall, though I don't know the specifics. Stuff to look into.
