Home » Audio » Craftsmen » Typically what is/isn't fixable?
Re: Typically what is/isn't fixable? [message #86441 is a reply to message #86390] Tue, 31 October 2017 21:10 Go to previous message
Hi, Anything can be fixed given unlimited resources. The answer to the question is more realistically.... that depends on who is asking and what is your skill level. The concept of cost to fix vs cost of replacement also fits into the mix. There are very few electronic things I can't fix. But then I have a few more skills than the average tinkerer. Also lots of test gear. To me the question is what is the cost factor and is the "broken" thing obsolete or a newer model available that makes the cost issue the over riding factor. For example there is no way I would seriously consider fixing a CRT based color TV. The parts are too costly and a new flat screen is both better and cheaper than the parts.
Previous Topic: First DIY Project?
Next Topic: Getting started with DIY
Current Time: Sat Nov 07 01:07:07 CST 2026
