Home » Audio » Radio » What is causing sound distortion?
What is causing sound distortion? [message #86397] Thu, 26 October 2017 23:51 Go to next message
The sound starts off fine, then it gets lower, then garbled, then is fine again, and it repeats the same problems. I don't think it's the station because this happens on other stations as well. It is constant though, just every once in a while.
Re: What is causing sound distortion? [message #86444 is a reply to message #86397] Tue, 31 October 2017 21:37 Go to previous messageGo to next message
Hi, more information is needed ...is this in the car, home, what type of equipment, is it AM, FM, Satelite, Digital....
Re: What is causing sound distortion? [message #86462 is a reply to message #86397] Wed, 01 November 2017 17:40 Go to previous messageGo to next message
It's a Radio Shack AM/FM radio. It doesn't play tapes or CDs or anything like that. The sound issue is constant, but just every once in a while - meaning, if the radio is on, the sound problem will happen, but not every single second. It might happen twice in five or ten minutes. It's a cycle - sounds fine, then low, then garbled, then normal. I guess the manual (if there was one) got lost when moving houses. When I googled the issue, I only found results about Radio Shack going out of business.
I should have mentioned the brand and type to begin with, I'm sorry about that. What profession fixes these issues in today's world? I have a hard time locating "fixers" now.
icon9.gif  Re: What is causing sound distortion? [message #86469 is a reply to message #86444] Fri, 03 November 2017 08:06 Go to previous message
Well, today the radio won't even turn on, so I'm sending it off to the proper recycling/dumping station. It sure was a good one for years and will be sadly missed. It's like losing a piece of history since Radio Shack is no more.
Gofar99, I greatly appreciate the time you put into helping me and others on here! You give detailed responses and never seem impatient. I really should have included what type of radio I was discussing in my original post.
Previous Topic: Subscription Radio
Next Topic: Do you still use a traditional radio?
Current Time: Fri Nov 06 22:43:42 CST 2026
