Home » Audio » Thermionic Emissions » Solid State vs. Vacuum Amps
Solid State vs. Vacuum Amps [message #86356] Fri, 20 October 2017 13:35 Go to next message
frankieg is currently offline  frankieg
What are the differences between solid state amps and vacuum amps? My roommate just started playing the guitar (and already thinks they are a rockstar) and is thinking about getting an amp. I told him I would ask the experts, ie you all. Is one better than the other, or do they just offer different things? Are there other kinds?
Re: Solid State vs. Vacuum Amps [message #86358 is a reply to message #86356] Fri, 20 October 2017 16:05 Go to previous messageGo to next message
There's a lot to consider, and it's more than just the active elements. You want to also consider the topology: Single-Ended, Push-Pull, Ultralinear, Parafeed, etc. Also consider where feedback is used and how much. Do some searches here or just peruse this forum and you'll find a lot of discussions on these topics.
But to get you started, check out this booklet:
Re: Solid State vs. Vacuum Amps [message #92478 is a reply to message #86356] Thu, 22 October 2020 20:18 Go to previous messageGo to next message
The Noise is currently offline  The Noise
It is interesting that Edison was able to patent something, part of the filament I believe, without knowing exactly HOW it worked. Could that even happen these days?
Re: Solid State vs. Vacuum Amps [message #92500 is a reply to message #92478] Sat, 24 October 2020 21:24 Go to previous messageGo to next message
Hi, there are a number of differences. Start with cost, power consumption and efficiency and heat generation. Add in amount of output power available and finally the one that is controversial is sound qualities. All of the first 4 mentioned tend to favor solid state amps. The last one is where the discussion gets murky. In theory any well designed amp should reproduce the source material well. If response figures, noise levels and distortion are equal the sound would logically be the same for either type. However, all things are seldom equal and the results are that they usually sound differently. Not bad or good, just different. So my suggestion is to listen to a few of each type and decide on what you like best. I personally prefer tube ones, but have a number of high end solid state ones as well. Often you will hear that folks say that tube amps have a "warmer" sound and solid state ones more detail sometimes to the point of being analytical. I don't personally share those thoughts (YMMV). I suspect that those comments probably made sense in the early days of solid state amps as the components and designs were not always as good as they are now. To be fair there were a lot of poor tube amps as well. Now both technologies are greatly refined and either type can fit most uses.
Re: Solid State vs. Vacuum Amps [message #92527 is a reply to message #86356] Mon, 26 October 2020 23:23 Go to previous messageGo to next message
Are we talking guitar amps or stereo amps?
Dave
Re: Solid State vs. Vacuum Amps [message #92868 is a reply to message #92527] Sun, 27 December 2020 20:11 Go to previous messageGo to next message
Off the top of my head, there are inherent differences between SS and Tube amplifiers due to the amplifying devices themselves. This may seem inconsequential, but I thought it would be beneficial for some.
1. Capacitance within the amplifying device. Vacuum tubes have a vacuum as a dielectric between the elements, hence virtually no DA or ESR/DA characteristics. SS devices, of course, have solid, semi conductor material with high DA and ESR/DF characteristics.
2. Miller Capacitance. The plate to no. 1 grid forms a capacitance, and that capacitance times the ~gain of the stage is called the Miller Capacitance, which the preceding stage "sees".
3. The internal junction capacitance in a FET varies with voltages across the junctions until ~25 volts and higher. Thus the Miller Capacitance varies as the signal varies in amplitude. Fortunately, the Miller Capacitance is low in some phase splitters and in output stages operated as source followers.
4. The power supply is quite different between Tube and SS. Where as vacuum tubes usually use a combination of chokes and small/medium size filter capacitors, SS generally uses vastly larger filter capacitors. The article "Picking Capacitors", by Walter Jung/Richard Marsh, shows that capacitors can have resonance in low khz. (See Below Attachment.)
In typical SS amplifiers, capacitances of 5 fold or more are often used.
This generally has a negative effect on sonics even though a typical sine wave may show low HD distortion. High DA and ESR/DF won't show up on a distortion analyzer.
Hope this helps in general understanding.
pos
/forum/index.php?t=getfile&id=2677&private=0
Re: Solid State vs. Vacuum Amps [message #99078 is a reply to message #92868] Thu, 06 November 2025 11:22 Go to previous messageGo to next message
Helen is currently offline  Helen
Oh, that’s fun! My husband actually talked about this once when he was looking at amps. From what I understand, solid-state amps use electronic circuits, so they’re usually lighter, cheaper and more reliable.
Vacuum tube amps (or valve amps) use old-style glass tubes and give that warmer, more “classic” sound that a lot of guitarists love. They just need a bit more care and can be costlier.
I don’t think one is exactly better because it depends on what sound your roommate likes. Tube amps sound smoother and more natural, while solid-state ones are cleaner and easier to maintain. There are also hybrid amps that try to give you the best of both. It might be fun for them to try a few in person to see what feels right.
Re: Solid State vs. Vacuum Amps [message #99123 is a reply to message #86356] Wed, 03 December 2025 06:54 Go to previous message
In general, I have found all tube/solid state designs are
quite inaccurate (specs mean virtually nothing except channel
separation high frequency response, damping factor etc within reason.
However, in my lab/audio company, retired for over a decade,
I was able to create a line pre-amplifier that listening
tested perceptually perfect to the source. Many musical selections
were used because of differing quality.
The amplifier was different as I used a constant load. When connecting
a reactive load, one has to match more carefully, both the correct total
gauge speaker wire for bass control, and parallel wires to minimize
reactance at higher frequencies. The wire type, Jenalabs 6N all copper,
worked nicely, and is quite superior sounding to 3N wire sold locally.
One caveat is that every component used, sources, line pre-amplifier,
monoblock amps use polypropylene capacitors in the place of electrolytic
capacitors in decoupling applications (except high voltage amplifier
power supply with electrolytics bypassed by a large polypropylene capacitor,
and multiple cathode bypass capacitors). As such, the system is extremely
transparent, perceived sonic differences down to 1 part in
4,000,000 reliably.
I would guess most audio systems would not be as sensitive, so
sonic differences may not be as noticeable.
cheers
pos
Previous Topic: TAD KT88
Next Topic: Tung-Sol 7581A vs Tung-Sol 6L6G Big Bottle
Current Time: Wed Nov 25 00:08:33 CST 2026
