Home » Audio » Pro Sound » Cheap Amps
Cheap Amps [message #85773] Thu, 03 August 2017 15:26 Go to next message
Saxon is currently offline  Saxon
My little cousin needs an amp for his guitar, but he doesn't need anything too fancy. Any recommendations for some cheap ones that work good?
Re: Cheap Amps [message #86032 is a reply to message #85773] Sun, 03 September 2017 19:07 Go to previous messageGo to next message
I'm not sure what price point you're hoping to stick with, but here are two suggestions. What about this one from Blackstar?
https://www.amazon.com/Blackstar-ID-1-Channel-Amplifier-Built/dp/B06WRVF636/ref=sr_1_1?ie=UTF8&qid=1504483389&sr=8-1&keywords=Blackstar+ID%3A+Core+10+V2
It's under $100 and has some cool built in effects that your cousin can experiment with.
There's also this Fender Mini.
https://www.amazon.com/Fender-Mini-Deluxe-Electric-Guitar/dp/B0002OP7VQ?tag=guitarfcom-20
It's a well known brand and is priced at $30, so it's affordable.
Your cousin might check the classifieds and Craigslist to find a better deal.
Re: Cheap Amps [message #86307 is a reply to message #85773] Wed, 11 October 2017 11:49 Go to previous messageGo to next message
WorkingWoman2017 is currently offline  WorkingWoman2017
I'm wanting to get an amp for my nephew for Christmas and these are some great ones to choose from. Thanks for the wonderful suggestions and I'm sure he will be happy!
Re: Cheap Amps [message #86598 is a reply to message #85773] Sun, 19 November 2017 12:10 Go to previous message
Solitary is currently offline  Solitary
I checked those out, and those are some great looking amps for that price. I was wondering, though if there aren't like different types that you could choose from, and how do you know if you got the right one for your cousin's needs?
Previous Topic: Isolation Pads
Next Topic: What is the best sampling rate?
Current Time: Fri Oct 30 05:27:17 CDT 2026
