Home » Audio » Group Build » Where to start?
Where to start? [message #85761] Wed, 02 August 2017 14:04 Go to next message
Keven is currently offline  Keven
Hey guys I am not great at putting things together, but I'd like to try in my free time as a hobby. What should I start with?
Re: Where to start? [message #85767 is a reply to message #85761] Wed, 02 August 2017 16:41 Go to previous messageGo to next message
Hi, I guess you need to decide on what sort of thing you want to create... speakers, amps, .... whatever.
Re: Where to start? [message #85824 is a reply to message #85761] Tue, 08 August 2017 01:09 Go to previous messageGo to next message
moss24 is currently offline  moss24
I have basic knowledge in Physics (electronics was never that easy for me) so I'm wondering if this really matters if I want to build speakers from scratch?
Re: Where to start? [message #85827 is a reply to message #85824] Tue, 08 August 2017 10:03 Go to previous messageGo to next message
Of course, an understanding of physics is fundamental when designing speakers. You need to work with things like mass/spring systems, resonance, wave propagation and electronics.
Re: Where to start? [message #86298 is a reply to message #85761] Tue, 10 October 2017 14:54 Go to previous messageGo to next message
Zohanna is currently offline  Zohanna
Wow, I never knew you needed physics to be able to build systems. I would have thought that you only needed a good understanding of electronics and those types of components. Well, now I know.
Re: Where to start? [message #86300 is a reply to message #86298] Tue, 10 October 2017 16:53 Go to previous messageGo to next message
To build the most kits, you only need to know technical trades like using hand tools and soldering. If you're going to build loudspeakers, you might need to have some carpentry skills.
Designing things is another matter. For amplifiers, you'll need to know advanced electronics and for loudspeakers you'll also need to know acoustics.
Re: Where to start? [message #87338 is a reply to message #85761] Fri, 02 March 2018 23:50 Go to previous messageGo to next message
Start with speaker cabinets. I could have sworn they taught us that in shop class in my sophmore year. You can't get more basic than that.
Re: Where to start? [message #99178 is a reply to message #85767] Wed, 21 January 2026 00:25 Go to previous message
Hank is currently offline  Hank
gofar99 wrote on Wed, 02 August 2017 16:41
You are right because deciding on what they wish to make is the first step towards deciding the direction that they wish to take. It is after that that they can now decide on learning more about the particular device that they want to assemble. If it is one that requires having a good foundation in physics, then the poster should know if it is one he can do.
Previous Topic: New Project IC phono preamp
Next Topic: Precautionary Measures
Current Time: Sat Nov 21 12:10:54 CST 2026
