I was told that the hum I get from my speakers sometimes is probably ground loop distortion. I understand that it means when your ground is coming from two different sources and they conflict. Is that about right?
Wayne Parham Messages: 19105 Registered: January 2001
Yes, that's right. Connect all equipment to the same wall socket. Also, if you have cable TV, install an isolator. It can be as simple as connecting a 75Ω-to-300Ω adapter followed immediately by a 300Ω-to-75Ω adapter. This will isolate the cable ground using a pair of antenna line matching transformers.
gofar99 Messages: 2060 Registered: May 2010 Location: Southern Arizona
Hi to follow on with what Wayne said...I had a serious hum and noise problem when I attached the CATV cable to an FW tuner I was using. When I measured it the open circuit (measured with a high impedance meter) voltage was just over 30VAC. The current was small, but it really upset the ground. I ended up switching to an antenna.
I've always known that a ground loop results when pieces of equipment are plugged into the AC at different locations, then connected together by signal cables that have a shielding connected to the ground. I think both Wayne and gofar have offered great solutions.
This helps bunches guys. I knew that the occasional hum I get when I run a couple of my components had something to do with the ground. Now I can attack this problem and get it fixed once and for all. Thanks.
