Home » Audio » Speaker » Jbl 2226h pair for subwoofer
Re: Jbl 2226h pair for subwoofer [message #85946 is a reply to message #85933] Fri, 25 August 2017 11:48 Go to previous messageGo to previous message
leimahmood is currently offline  leimahmood
Wayne Parham wrote on Thu, 24 August 2017 16:58
Make the box 35" wide x 22" tall x 13" deep. Use two 4" diameter ports that are 5-1/2" long. Use 3/4" or 18mm Baltic Birch or MDF. Brace well using cross-braces (front-to-back and side-to-side) on each side of the woofer along the 35" dimension. The braces can be made using scrap cut from the panels.
If i select the box dimension
35 tall
22 wide
13 deep
Is it still fine
Dus to space in room
Previous Topic: Two good deals on speakers
Next Topic: Will they get smaller?
Current Time: Mon Nov 23 00:05:55 CST 2026
