Home » Audio » Home Theater » What wattage is recommended?
Re: What wattage is recommended? [message #85577 is a reply to message #85567] Sat, 08 July 2017 12:47 Go to previous messageGo to previous message
Power requirements are based on the efficiency of the loudspeaker system(s) and the size of the room. If you have a speaker that is able to generate 98dB one meter away with one watt input power, then you'll need four times less power than a speaker that only generates 92dB at one meter with one watt input.
Previous Topic: How Long Did It Take You To Set Up System?
Next Topic: Lens replacement
Current Time: Sun Oct 18 07:40:46 CDT 2026
