Home » Audio » Speaker » Eminence Delta Pro 8-A in a JBL AM6200-64 horn project (horn project)
Re: Eminence Delta Pro 8-A in a JBL AM6200-64 horn project [message #85423 is a reply to message #85422] Thu, 15 June 2017 15:40 Go to previous messageGo to previous message
brad944911 is currently offline  brad944911
Wayne,
Yes sir, I did research this site quite a lot over the last week or so...great(and a bit overwhelming at times) info on SEVERAL topics. I followed the white rabbit down several holes Rolling Eyes
I guess I should've mentioned that this part of the project is just for the mid bass/midrange. I already have the bass cabs and tweeters lined up; this was the last piece of the puzzle.
I also omitted all info system-wise...I apologize. For reference, I look to use this mid horn for 300Hz to 2KHz roughly. I will be tri-amping the system and using all active crossovers as well as EQ'ing. I have rudimentary measurement gear to check progress/regress.
Mostly I was looking to see if someone versed in Hornresp would run a mock-up so I could validate/scrap what I have. I know it's a lot of trouble, but so is all the wood working on a compressed schedule. Just thought it was worth a shot.
If these are a miserable failure, I guess I can get some of your horns...they were originally my plan until I fell into these JBL faces.
Thanks for the response and for maintaining this site.
Brad
Previous Topic: How much are you willing to pay.
Next Topic: How much are speakers shrinking?
Current Time: Wed Nov 04 04:12:57 CST 2026
