Home » Sponsored » Pi Speakers » Rs loading (resistor)
Rs loading [message #85364] Tue, 06 June 2017 16:52 Go to next message
mellotron is currently offline  mellotron
Hi,
I'm sourcing parts for a 4pi build and was wondering about the value for the Rs resistor rated at 16 ohms for the B&C 250. There weren't any 16 ohm available. I was just wondering if it would be ok to use something a bit higher (18ohm) or lower (12ohm) in this position. Thanks for any assistance.
Re: Rs loading [message #85376 is a reply to message #85364] Wed, 07 June 2017 09:02 Go to previous messageGo to next message
Either would work, but I'd go with the 18Ω part. The 12Ω resistor will provide more damping, which is good, but it will also attenuate the driver too much, which we don't. Better yet, order the right part online and have it shipped to you.
Re: Rs loading [message #85377 is a reply to message #85376] Wed, 07 June 2017 09:10 Go to previous message
OK. Thanks for that. I will stick with the parts as suggested.
Previous Topic: Pi 4 vs JBL 4430? Wayne?
Next Topic: Mid horn driver options
Current Time: Mon Oct 12 09:36:07 CDT 2026
