Home » Audio » General » Colors And Music
Colors And Music [message #76530] Sat, 27 April 2013 15:57 Go to next message
If you had, or actually have, your own studio would you put a lot of consideration into what color you would paint it? Some people think that some colors are more conducive to creativity than others.
Re: Colors And Music [message #76547 is a reply to message #76530] Mon, 29 April 2013 16:42 Go to previous messageGo to next message
Why paint, put wood grain with white drywall and use rgb lighting on it to change the mood of the room for musicians.
Re: Colors And Music [message #76554 is a reply to message #76530] Mon, 29 April 2013 22:03 Go to previous messageGo to next message
Azuri is currently offline  Azuri
I can sort of see the point, but unless the musicians only play the same type of music, paint would get kind of redundant after awhile. Like Bill said, switch it up with different lighting.
Re: Colors And Music [message #85311 is a reply to message #76530] Fri, 02 June 2017 22:13 Go to previous messageGo to next message
PlayerNM is currently offline  PlayerNM
Yes I would be concerned with color. I think pastels in blue or green are more calming than say red or black. I need to feel calm and relaxed when I'm producing music.
Re: Colors And Music [message #85329 is a reply to message #76530] Sat, 03 June 2017 14:46 Go to previous message
Keven is currently offline  Keven
This is a tricky subject. I would definitely want to paint my walls a certain color, but like others mentioned it would be hard to make one color fit different types and moods of music.
Previous Topic: What is a best age to start a child on learning music?
Next Topic: Protecting headphones from sweat
Current Time: Sun Nov 08 03:00:12 CST 2026
