Home » Audio » General » Dusty Speakers?
Dusty Speakers? [message #84859] Fri, 31 March 2017 03:23 Go to next message
vhfspeeks is currently offline  vhfspeeks
The sound in my speakers sounded slightly 'off' recently. When I started having a look they seem to have built up dust in them, which isn't helping the sound. I've cleaned it out as best I can, but how can I stop this happening without reducing the sound quality?
Re: Dusty Speakers? [message #84860 is a reply to message #84859] Fri, 31 March 2017 12:42 Go to previous messageGo to next message
Nouri is currently offline  Nouri
If you're asking how you can keep the sound quality even if the speakers collect dust, you can't. I don't know why you would want to. Keeping your stereo clean is a part of ownership.
Re: Dusty Speakers? [message #84865 is a reply to message #84859] Sat, 01 April 2017 06:00 Go to previous messageGo to next message
chatzy02 is currently offline  chatzy02
I suppose what you're asking is how to keep the dust from collecting in the speakers in the first place? I don't know if it's at all possible to avoid this, but I would like to find out if anyone here knows a way.
Re: Dusty Speakers? [message #84868 is a reply to message #84865] Sat, 01 April 2017 15:40 Go to previous messageGo to next message
Hi, Dust is a problem with my electrostatics....however they came with very nice dust covers. Short of doing the same for yours I really don't see any alternative. I suppose you try using a hand held dust vac on them when you clean house...Mine actually say that is fine and I have done it from time to time.
Re: Dusty Speakers? [message #84875 is a reply to message #84860] Mon, 03 April 2017 00:54 Go to previous messageGo to next message
Nouri wrote on Fri, 31 March 2017 12:42
No, what I wanted to know is if there is a way to stop it collecting as much dust which won't compromise the sound quality. Dust covers would make it muffled.
Re: Dusty Speakers? [message #84878 is a reply to message #84875] Mon, 03 April 2017 16:23 Go to previous messageGo to next message
vhfspeeks wrote on Mon, 03 April 2017 01:54
Speaker covers can muffle the sound,
but they serve as good dust covers and also light impact protection.
I usually remove them for good listening.
Re: Dusty Speakers? [message #84887 is a reply to message #84878] Tue, 04 April 2017 17:54 Go to previous messageGo to next message
Hi, I did not mean to imply that you leave them on when listening. That would be awful. Just use them in between times of listening. Here (Arizona) dust is a serious problem and covers are a must. For conventional speakers something simple like a table cloth or towel would be fine.
Re: Dusty Speakers? [message #84889 is a reply to message #84859] Wed, 05 April 2017 03:40 Go to previous messageGo to next message
bcharlton is currently offline  bcharlton
Where I stay, there's a lot of dust so I've made it a routine to always have the speakers with covers whenever I'm not using them. They still gather dust at times though but this can always be easily cleaned.
Re: Dusty Speakers? [message #84896 is a reply to message #84889] Wed, 05 April 2017 21:12 Go to previous message
Hi, I though you all might get a laugh from what Martin Logan recommends to do to the electrostatics I own when they get dusty. BTW they will crackle when that happens. They say to use a vacuum cleaner on them! I was hesitant at first as the Mylar diaphragms seem fragile...they are not and it works fine. Rolling Eyes
Previous Topic: No Sound At All
Next Topic: Sophie's Place / Musical Therapy
Current Time: Mon Jul 14 05:55:17 CDT 2025
