Home » xyzzy » Dungeon » Keeping the noise out
Re: Keeping the noise out [message #84667 is a reply to message #84652] Sat, 04 March 2017 14:38 Go to previous messageGo to previous message
Hi, A sort of difficult to answer question as it depends on when the noise is problem and what the noise actually is. If it is just day to day racket...then you have a serious problem and unless you want to wear ear plugs all day it will not be easy to get rid of. Yes you can use a music player with head phones and that will mask the noise, but it will in its own way cause problems. If you want to make a room quieter...it is possible, but expensive. Sound deadening, baffles in air ducts, extra wall board levels, and so on. It would probably be cheaper to move out. BTW I find that quality over the ear phones actually seem better than noise cancelling ones. Snug in ear ones can be even better.
Previous Topic: CCTV cameras with great sound quality
Next Topic: Any karaoke fans here?
Current Time: Sat Nov 21 09:09:19 CST 2026
