Home » xyzzy » Dungeon » Keeping the noise out
Keeping the noise out [message #84652] Thu, 02 March 2017 14:13 Go to next message
Vernon is currently offline  Vernon
I know most of us on this forum are more concerned about creating the sound but what if you're trying to keep it out? What's the best thing to use if you want peace and quiet but you stay with noisy teenagers?
Re: Keeping the noise out [message #84667 is a reply to message #84652] Sat, 04 March 2017 14:38 Go to previous messageGo to next message
Hi, A sort of difficult to answer question as it depends on when the noise is problem and what the noise actually is. If it is just day to day racket...then you have a serious problem and unless you want to wear ear plugs all day it will not be easy to get rid of. Yes you can use a music player with head phones and that will mask the noise, but it will in its own way cause problems. If you want to make a room quieter...it is possible, but expensive. Sound deadening, baffles in air ducts, extra wall board levels, and so on. It would probably be cheaper to move out. BTW I find that quality over the ear phones actually seem better than noise cancelling ones. Snug in ear ones can be even better.
Re: Keeping the noise out [message #84679 is a reply to message #84652] Mon, 06 March 2017 16:16 Go to previous message
Cortney is currently offline  Cortney
It depends on what level of noise you're trying to keep out. I agree that you may have to work on your room to keep the sound out. Other than that, you'd have to use more sound to cover it...
Previous Topic: CCTV cameras with great sound quality
Next Topic: Any karaoke fans here?
Current Time: Fri Nov 13 18:11:11 CST 2026
