Home » Audio » Home Theater » No audio for PC
Re: No audio for PC [message #84496 is a reply to message #84482] Mon, 06 February 2017 14:33 Go to previous message
You don't need a special plug for PC audio...any spare line level one (aux, tape, cd etc) will do. If you want to directly use something like a USB connection then an adapter will be needed that converts USB to audio. Same goes for optical and similar PC outputs. Most AV gear now has HDMI inputs and now many PCs do as well. That IMO is the best way to connect. Older gear often does not have HDMI capability.
Previous Topic: Cleaning the DVD player
Next Topic: Smart home theater
Current Time: Mon Oct 12 03:20:41 CDT 2026
