Home » Audio » Home Theater » What to check first
What to check first [message #84070] Mon, 12 December 2016 10:23 Go to next message
When purchasing a new home theater, is it okay to test it at the point of purchase? I always try to avoid a situation where you have purchased an item, then it starts malfunctioning even before being used. What else should be considered?
Re: What to check first [message #84132 is a reply to message #84070] Sat, 17 December 2016 02:39 Go to previous message
Tadtone is currently offline  Tadtone
If the shop will let you, I don't see a problem with that. They should have a demo version available so you can get an idea of what you are buying and what it can do. If you are buying online, all I can say is make sure there's a good return policy!
Previous Topic: Going wireless
Next Topic: Matching your speakers
Current Time: Fri Nov 13 07:11:38 CST 2026
