Home » Audio » Speaker » Small speaker flanking sub limitations.
Re: Small speaker flanking sub limitations. [message #83805 is a reply to message #83791] Thu, 27 October 2016 15:17 Go to previous messageGo to previous message
jonone is currently offline  jonone
I suppose I need to measure the response with the mains run full range vs with a 80hz high pass applied, and see how it effects the response.
The manufactures of my speakers response to the question of using a high pass filter was basically you do get intermod distortion when full range but it's not audible and for a high pass to be effective against it it would need to be over 100hz and they saw that as more of a problem.
Do you think it's worth adding a high pass to help over excursion if it doesn't effect the response Wayne?
Do you think over excursion is audible/ a real world problem or do you think it's not worth it for the smoothest response.
Previous Topic: Class d for flanking subs
Next Topic: In Wall Speakers
Current Time: Fri Nov 27 05:33:43 CST 2026
