Home » Audio » Thermionic Emissions » tube rectifiers
Re: tube rectifiers [message #8311 is a reply to message #8308] Wed, 07 July 2004 23:17 Go to previous messageGo to previous message
metasonix is currently offline  metasonix
A tube rectifier has a major advantage, built-in slow warmup. But it has a lot of disadvantages--wasting power, needing a separate filament winding, causing massive destruction if it develops gas, etc.
Cheap diodes have slew-rate problems which can increase the noise floor in the amp. I'd use FREDs, and a time delay switch or standby switch. And recommend you precede each diode with a 100-ohm 5w resistor to reduce the turn-on surge. That simple trick can increase reliability of the power supply considerably.
Previous Topic: Wave 20 AV - 20 DT
Next Topic: Tube Power Amp Schematics
Current Time: Sat Oct 17 13:08:17 CDT 2026
