Home » Audio » Speaker » Mono "flanking sub"
Re: Mono "flanking sub" [message #83036 is a reply to message #81624] Sun, 17 July 2016 10:04 Go to previous messageGo to previous message
jonone is currently offline  jonone
Wayne Is there an explanation why zero delay was flatter then most other options I tried? Any delay configuration I tried just moved the dips somewhere else in the response?
One thing I did try before I got my new amp was to change the mains distance to further away then the real distance /auto setup suggested distance,as I think because the sub goes through eq and sub amp it's probably behind the mains in arrival time? And delaying the subs only made this gap bigger, I know this is not the idea behind multiple subs, but from memory it may have helped raise the dip slightly in the 100hz area... I need to try it again with the new amp, I just did auto setup for distance etc.
Previous Topic: One Speaker Wi-Fi
Next Topic: Class d for flanking subs
Current Time: Fri Nov 06 23:08:29 CST 2026
