Home » Audio » General » Here's An idea
Here's An idea [message #82903] Sat, 25 June 2016 22:27 Go to next message
The Noise is currently offline  The Noise
You get home from work and open your front door. When you do, your sound system is activated and turns on whatever mode you programmed into it. The radio, CD, record player, etc....
Is there anything like that on the market right now?
Re: Here's An idea [message #82919 is a reply to message #82903] Sun, 26 June 2016 08:53 Go to previous messageGo to next message
I'm not sure.
You could use a timer if your arrival times are consistent.
Why not set it for an hour or two ahead?
Gotta warm up those tubes you know Very Happy .
Re: Here's An idea [message #82934 is a reply to message #82903] Sun, 26 June 2016 19:04 Go to previous messageGo to next message
Nouri is currently offline  Nouri
There will be in about 2 years. I'm starting the patent process as we speak. Thanks for the opportunity for me to get rich, I appreciate that. Very Happy
Re: Here's An idea [message #82939 is a reply to message #82903] Mon, 27 June 2016 01:34 Go to previous messageGo to next message
cwemoy is currently offline  cwemoy
For a moment, I almost thought this was already a reality. This looks like a really brilliant idea that will appeal to a lot of people.
Re: Here's An idea [message #83049 is a reply to message #82903] Mon, 18 July 2016 07:34 Go to previous messageGo to next message
Lizah is currently offline  Lizah
This does sound like a really great idea. What would be even better is if the system would know who is actually walking through the door at the time. That way you don't end up having to listen to someone else's music selection.
Re: Here's An idea [message #83058 is a reply to message #83049] Tue, 19 July 2016 18:16 Go to previous message
Have it keyed to a proximity or motion sensor that triggers when you walk to the door. Depending on the audio gear it should be possible. I would use a manually controlled amp so the volume and input could be pre-selected. Any source could be used as long as it starts up in the mode you want. A vinyl LP would be perfect as you could have it in the start mode and turn the power off before you left. It would continue to "start" when the power came back on. Lots of possibilities. A digital system could be even better with it preprogramed to do what you want.
Previous Topic: RCA line level crossover
Next Topic: RIP Scotty Moore
Current Time: Mon Nov 16 08:16:04 CST 2026
