Home » Audio » Speaker » Testing The Bass
Testing The Bass [message #82899] Sat, 25 June 2016 15:00 Go to next message
The Noise is currently offline  The Noise
If you bought a new set of speakers and wanted to test out the bass output, what would you play? Classical? Punk? Rap? What genre do you think would be best suited for this?
Re: Testing The Bass [message #82924 is a reply to message #82899] Sun, 26 June 2016 10:01 Go to previous message
The Noise wrote on Sat, 25 June 2016 15:00
If I was to choose between the three genres, I would go with rap or hip hop because of the possibility of low pitch that is characteristic of this genre. All in all, I believe a good speaker can have the bass output tested using whichever genre.
Previous Topic: Single speaker system
Next Topic: Sound synchronizing
Current Time: Fri Nov 06 21:35:41 CST 2026
