Home » Sponsored » Pi Speakers » 4 Pi plans
4 Pi plans [message #82737] Thu, 26 May 2016 14:12 Go to next message
Paolo is currently offline  Paolo
Hello Wayne, could you send me the constructive plans for 4 Pi speakers, and the crossover circuit dedicated to eminece H290?
Thanks for your time
Re: 4 Pi plans [message #82744 is a reply to message #82737] Fri, 27 May 2016 10:55 Go to previous message
You've got mail!
Note: The schematic is for our H290C waveguide, not the old Eminence radial horn. However, the only difference is you must remove resistor Rs and add 0.47uF capacitor C1 when using the radial horn.
I suggest that you not do that. The radial horn was very good, but the H290C waveguide is much better. It doesn't cost much more and is well worth it.
Previous Topic: 4pi 100 watt 8ohm resister?
Next Topic: Non-inductive Load Resistor Inductance Reading
Current Time: Mon Nov 23 02:19:09 CST 2026
