Home » Audio » Home Theater » Choosing the best home theater
Choosing the best home theater [message #82662] Sun, 22 May 2016 12:35 Go to next message
If you frequent the cinemas and experience the great sound quality, you will have an urge to make sure you have a good sound system at home.
What are some of the factors to consider when looking for the best home theater? Apart from the brand, what else should be put into consideration.
Re: Choosing the best home theater [message #82732 is a reply to message #82662] Thu, 26 May 2016 06:19 Go to previous messageGo to next message
Finn is currently offline  Finn
Brand will certainly play a big role in choosing the perfect system, but don't forget to think about size. The size of your room is going to matter a lot because if it is a big room then you need full-size, full-range speakers with a powerful amplifier.
Re: Choosing the best home theater [message #82761 is a reply to message #82732] Tue, 31 May 2016 15:33 Go to previous message
moss24 is currently offline  moss24
Finn wrote on Thu, 26 May 2016 06:19
I agree with Finn on this one. The bigger your room, the greater the specifications. I think the important thing is to do a thorough analysis of what your preferences are and then settle on a home theater that fits the bill.
Previous Topic: The Purple Flare Power Cord
Next Topic: An Extended Warranty
Current Time: Thu Nov 26 18:50:31 CST 2026
