Home » Sponsored » Pi Speakers » 4 Pi build questions
4 Pi build questions [message #82593] Fri, 06 May 2016 09:34 Go to previous message
brookhart995 is currently offline  brookhart995
I am getting my materials ready to start this build and I have a few questions.
I am using the Eminence PSD2002-S 8ohm horn driver and the JBL 2226H woofer. I was able to get both at reasonable prices (used). The horn flare is specified as the H290c, is there a difference between this flare and the H290s that P.E. sells? In the crossover schematic it shows a 100watt 8ohm resister that is in line with the positive terminal of the woofer, is this the type of resister I need to use?
http://www.mouser.com/ProductDetail/ARCOL-Ohmite/HS100-8R-F/?qs=sGAEpiMZZMtlubZbdhIBIEidPY%252bx%2fLaaBDWQceqDgFs%3d
As for the speaker box design I was thinking of something like this?
http://www.critesspeakers.com/_Media/csiiready_med.jpeg
The main design detail I like is the recessed baffle that would allow a flush grill. Would doing this compromise the sound quality as it would need to be designed this way when the crossover is designed?
Thanks for helping me out.
Ryan
Previous Topic: 4 Pi Flush Mounting Information (2016)
Next Topic: 4pi 100 watt 8ohm resister?
Current Time: Mon Oct 19 02:23:40 CDT 2026
