Home » Sponsored » Pi Speakers » 4 Pi Flush Mounting Information (2016)
4 Pi Flush Mounting Information (2016) [message #82577] Tue, 03 May 2016 23:19 Go to next message
j0nnyfive is currently offline  j0nnyfive
Howdy,
'Been doin' some power searchin'. Very Happy
I intend for this thread to be a little helper thread for some odds and ends about flush-mounting the 4 Pi speakers for newbies like myself. 'Hope ya'll don't mind. Smile
H290C HORN
Inside cutout dimensions: Height = 5" Width = 10 and 1/2" (per plans)
Depth of recess: 1/4"
Outside cutout dimensions: Height = 6 and 9/16" Width = 11 and 5/8" Corners = 90* of 1.6" diameter
JBL 2226H CONE
Inside cutout dimensions: Diameter = 13 and 15/16" (per plans)
Depth of recess: 5/8"
Outside cutout dimensions: Diameter = 15 and 17/64" (388 mm) (per JBL document)
QUESTIONS (For Wayne and all other experienced people):
BINDING POST PLATE
Cutout dimensions: Height = 2 and 1/8" Width = 2 and 7/8" (Is this correct or backwards?)
Not that it matters much, but how high up from the bottom edge do you cut this hole?
GASKETS FOR HORN AND WOOFER
Do you still make gaskets with the shower pan PVC plastic?
(insert link for gaskets here)
DEPTH THICKNESS
Does the thickness of veneer or the thickness of gaskets affect the routed depth thickness above?
SUPPORT RINGS BEHIND THE CUTOUT PARTS
Made of scrap wood, glued behind routed cutouts with T-nuts or threaded inserts in it.
What do you recommend for the dimensions of this support ring?
(insert link for mounting screws and T-nuts here)
AUDIBLE DIFFERENCE
Does flush mounting make any audible difference with the 4 Pi speaker, or is it cosmetic only?
If any of the above information is wrong, please feel free to correct it. Thanks!!!
Re: 4 Pi Flush Mounting Information (2016) [message #82581 is a reply to message #82577] Wed, 04 May 2016 11:07 Go to previous messageGo to next message
This is a very useful thread, thank you!
My 2ยข:
Flush mounting does nothing for the acoustics, but it's great for aesthetics, at least in my opinion. I really like the look.
I use gaskets under the waveguide, the crossover board and under any other part or panel that might buzz or leak. Midwoofers too, but they usually have a gasket built-in. The 2226 is an exception - I don't use the O-Ring supplied and use a PVC gasket instead.
The PVC gasket material is 40 mils thick.
As for scrap wood behind the mounting holes, when I have cabinets routed for flush mounting, the remaining wood thickness is small. So like you mentoned, I add a panel of wood behind it to make it thicker in that local area. I sometimes use a ring, sometimes just a square piece of wood. Occasionally I'll have the whole baffle made double thick. It's all pretty low-tech, and no reason to overthink the process.
The binding post plate can be mounted anywhere. I like to put it near the bottom, about two or three inches up and centered.
Re: 4 Pi Flush Mounting Information (2016) [message #82583 is a reply to message #82577] Wed, 04 May 2016 19:14 Go to previous messageGo to next message
Thanks for the information!
I'm almost ready to get the boxes built. I think I'm going to skip the flush mounting for now just to reduce the odds of $um Ting Wong!
I found some old pictures online of earlier 4 Pi speakers with the parts mounted directly on the baffle, and I think they look good too! Sort of an old school rugged look. Flush mounted looks awesome as well. As long as it doesn't affect the sound either way, I'm good with it.
One last thing, did I correctly understand the width and height of the binding post plate cutout, or did I get it backwards?
Thanks again! Smile
Re: 4 Pi Flush Mounting Information (2016) [message #82589 is a reply to message #82583] Thu, 05 May 2016 10:31 Go to previous messageGo to next message
The plate is wider than tall, if you like the binding posts side-by-side:
http://www.pispeakers.com/Connector_Panel.jpg
Re: 4 Pi Flush Mounting Information (2016) [message #82591 is a reply to message #82589] Thu, 05 May 2016 22:43 Go to previous messageGo to next message
Great. Thanks!
I may have been just kidding about not flush mounting... I'm in communication with a guy here about this build. Will ask about this. Stay tuned.
When I get them built, I will post pics!!
Re: 4 Pi Flush Mounting Information (2016) [message #82594 is a reply to message #82591] Fri, 06 May 2016 10:36 Go to previous message
Please do!
Previous Topic: Dimensions for the speaker box terminal plate cutout
Next Topic: 4 Pi build questions
Current Time: Fri Nov 13 07:26:53 CST 2026
